Wait for the digital signal
Is there like "wait for the panel activity" in digital signal, "wait for the digital signal goes up" etc. ?
Or is it bad to make it with sequence structure and inside of first sequence use while loop?
(2,882 Views)
If you need to wait for a digital signal before continuing on with your program, the best way is to have a while loop that continuously reads the signal and stops the loop when the signal goes high. You can put this loop in the first frame of a sequence, or you can wire an output from the loop (like error out from the device read vi) into your next step. Be sure to put a delay (100mSec) in your loop so that the loop does not hog CPU time.
- tbob
Inventor of the WORM Global
(2,878 Views)
Thank you for your answer.
Second thing is that how much it makes charge to computer if i have like 5 different waiting loops at the same time?
(2,868 Views)
As long as each loop has some time delay, having 5 loops won't make any noticable difference.
- tbob
(2,859 Views)
