Want to Tranmit and Receive an Audio file separately. Need Help??
Basically i m implementing OFDM (Orthogonal Frequency Division Multiplexing) and data to process is an audio (wav) file. All i want is to transmit and receive audio file with separate transmitter and reciever. Both transmitter and receiver are working in combination (i.e in single VI) but when i separated them, transmitter is giving no response. Please tell what should i do?
(3,005 Views)
Hi Zaib,
even when you also want to transmit images too (in the other thread) you didn't show what you have done so far...
Attach your vi(s) and point directly to the problem!
(2,995 Views)
Hi Zaib
It seams that you want to receive a lot, but you are not very interesting in transmitting something;) Before you post some code, we can not help you. This forum will probably offer you some advices. But you will never receive a "turn key" ready application.
Besides which, my opinion is that Express VIs Carthage must be destroyed deleted
(Sorry no Labview "brag list" so far)
(2,967 Views)
