Want to combine two 2d arrays with different numbers of rows
I did, when I had all the transposes in there, the file came out in just 2 columns.
When I took them out, it came out all nicely formatted
See attached, it looks f*** beautiful, haha.
Thanks again! 🙂
Message 11 of 13
(1,098 Views)
If you don't use transpose then what's shown in the attached screenshot will happen.  You have a True constant wired to your version of the spreadsheet VIs, and if you kept the same terminals then you are transposing when reading and writing the file, so your transpose is embedded inside the subVIs.
Message 12 of 13
(1,087 Views)
Ah, okay
Yeah, I attached what I did, just to show.
Message 13 of 13
(1,081 Views)
