Want to generate current loop from LabVIEW
I want to develop 6 current loop (2ma-24ma) inputs to my machine from labview. Could you please help me which cDAQ I should and should be the correct approach.
Prashant
Message 1 of 9
(4,774 Views)
The NI-9265 has 4 analog output channels for current.  So you'd need two of those.  It is 0-20 mA.  You said you needed up to 24 mA?  That is a very unusual specification.  Most current loops are going to be 0-20 or 4-20 mA.
Message 2 of 9
(4,767 Views)
It was 2-22 ma, Yes it is unusual, But we have to have 22 ma for short circuit condition. Kindly suggest.
Prashant
Message 3 of 9
(4,757 Views)
Contact your local NI sales representative.
Message 4 of 9
(4,752 Views)
UPRR,
Here is a document describing how to do exactly what you want to do.
http://ae.natinst.com/public.nsf/web/searchinternal/B990B1BB8C6228F286256DDA005526E0
If you want to use cDAQ you will need 3 NI-9265 as they have 4 outputs and you require 2 outputs per 2-24mA current loop.
Hope this proves useful,
Pete
Peter C.
Message 5 of 9
(4,712 Views)
Peter,
That link is broken.  Only NI employees can see the internal ae.natinst.com domain.
Let me guess what it is doing.  It is using two output channels in parallel and each channel is sourcing half the needed current.
Message 6 of 9
(4,701 Views)
My mistake, and yes...your guess is exactly right.  🙂
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019OZgSAM&l=en-US
thanks for pointing out the broken link...kudos to you sir!
Peter C.
Message 7 of 9
(4,698 Views)
That one had an extra http:// at the end breaking it.
Try this one.  https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019OZgSAM&l=en-US
Message 8 of 9
(4,682 Views)
Haha,
Wow...I was really on my game yesterday huh?    Thanks again.
Peter C.
Message 9 of 9
(4,652 Views)
