Want to implement scaling in FPGA target.
There is a scaling and divisiong module solution posted in the forums. The program is fairly simple however the scaling index is being calculated automatically when the program is being run. I would like to dump the same code into the FPGA but the target is not supproting this. Any solutions?
(2,516 Views)
Please provide the link (url) to the posted solution you are referring to so that a solution can be suggested.
Cheers!!!
(2,449 Views)
