Want to produce an executable from LV2015 that runs with the 2010 RTE
I use LV 2015 but need to deploy a program written in this to a PC with only the 2010 LV Runtime Engine. For various reasons I don't want to update the RTE. Is it possible to compile from the 2015 project so my program will run with the 2010 RTE?
(2,950 Views)
Accepted by RavensFan
No.
You will either need to download LV 2010 or install the LV 2015 runtime.
What reason don't you want to install the newer runtime?  You can have multiple runtime versions installed.
(2,920 Views)
Accepted by topic author another_novice
Please not that multiple version of the LabVIEW RTE can be installed alongside each other. There is no need to limit yourself to one single RTE version only on any PC.
Rolf Kalbermatter  My Blog
(2,892 Views)
Appreciate the advice. I didn't know I could have multiple RTE's.
Thanks a lot!
(2,861 Views)
