Want to trigger I/O current, Voltage with the help of toggle button array
I am new in LabVIEW but I need to develop one VI that trigger the Inputs to Voltage/Current to cDAQmx, I got some VIs ready in NI example but I need to make a single VI which can handle I/Os with the help of toggle button array. Please suggest
Prashant
(3,395 Views)
Hi
Is it a software or physical button?, is you are using a button in Labview you can trigger the output with an event structure of value change. Have you used events before?
Regards
Jaime Peña
National Instruments Mexico
Ingeniería de Aplicaciones
www.ni.com/soporte
(3,391 Views)
I want to trigger from LabVIEW only, I did some small work on event structure. Could you suggest some refernece VIs you something else? and I have a array of Input buttons.
Prashant
(3,386 Views)
Hi, you can try with the code of this image, just need to find the button that has changed its value and procees it with a case structure. Regardsevent.jpg
Jaime Peña
www.ni.com/soporte
(3,377 Views)
Could you please share the VI file?
Prashant
(3,374 Views)
Why are you using an array of booleans for input?  What happens if you press more than 1 button?
Use an enumerated pulldown selector or radio buttons or just separate buttons you can name and then trigger your event structure with them.
LabVIEW Pro Dev & Measurement Studio Pro (VS Pro) 2019
(3,371 Views)
Yes , he could use independent buttons instead of an array of inputs. And have an event for each button, that will make this easier
Regards
Jaime Peña
www.ni.com/soporte
(3,368 Views)
