Warning: connection to the target (cRIO)has been lost
Hey,
When I am running this particular VI attached below (have also added a picture of it), the cRIO 9045 automatically gets disconnected after running for couple of seconds and showing the warning  " connection to the cRIO has been lost ".Then for second time i have to reconnect the cRIO and then deploying the program. I am using Labview 2020 SP1.
Can anyone find the reason for this warning? Thank you for your help with this.
(1,409 Views)
Hi Draka,
I only had those "connection lost" messages when the cRIO was on (CPU) overload…
Did you check the CPU load?
  • Do you really need to write to a shared variable at 1kHz?
  • Do you really need to read from that shared variable also at 1kHz?
  • Do you really need to write to a file at 1kHz?
  • Why don't you use a queue/FIFO to send data from one loop to the other?
  • Why do you need to use DDT wires?
  • Do you really want to read 1 sample/ch at 1kS/s? Why don't you setup the DAQmx task using plain DAQmx functions, including DAQmxTiming to define the sample rate?
  • Why do you need 3 IndexArray nodes to index 3 elements from the same array?
(1,399 Views)
Hey GerdW,
Thank you for your answer.
I am pretty new to LabVIEW and know not that much about it. I want to gather data and log\save it on the device.
How do I check the cpu load ?
I think I do not need to write to a file or shared variable or read it at 1 kHz i only want to save the whole data I get from my sensors.
previously I used a FIFO but had the same problem.
I will change the DDT wires.
I thought it will be easier and faster with the DAQ assistant.
Best,
Draka
(1,390 Views)
Hi Draka,
Nope!
Read this!
There's a RTGetCPULoads function…
(1,360 Views)
