Warning: has been deleted, renamed...
I am using LV 8.5, and in the project explorer window, one of my vi's "Read lines from file with no error.vi" has a warning message next to it stating "Warning: has been deleted, renamed, or moved on disk".
It doesn't appear that this vi exists anymore in the vi.lib. What can I do to fix this?
(5,523 Views)
Repair your LabVIEW installation.  It should restore the VI.  This assumes the VI is part of the LabVIEW installation.  If it belongs to a different toolkit or driver, you will need to repair that toolkit or driver.  Finally, if you or someone else added it on a different computer, you will need to get it and put it in the same location.  My copy of LabVIEW 8.5 does not have a VI with this name, so this may be the case.
(5,515 Views)
I encounted the same problem when i try to open the keithley 27xx.lib,but i have resloved it,the problem is that the directory is too complex to find it!
 The wrong directory-->C:\Program Files\National Instruments\LabVIEW 2011\instr.lib\keithley2700\Keithley 27XX\keithley 27xx.lvlib
 The right directory-->C:\Program Files\National Instruments\LabVIEW 2011\instr.lib\Keithley 27XX\keithley 27xx.lvlib
you can see,if delete the part of "keithley 2700" in the directory,then when opening the "keithley 27xx.lvlib"again,there doesn't come out the waining:has been deleted,renamed......
  Just a reference,i don't know wether it comply with you or not!
(5,471 Views)
Hey Du Wei,
I am sorry to hear about the problems finding the right directory for these files.  I believe that it is structured like that so that it can cover an entire series of devices. Did you download these drivers from the National Instruments Instrument Driver Network?
Glad you were able to get it figured out and working!
Joe S
(5,445 Views)
