Watlow EZ-Zone (R) LabVIEW Driver
I'm using the Watlow EZ-Zone LabVIEW Driver Example.vi to read the temperature of my Watlow controller with the "Parameter" set to 4001.  Does anyone know how to find the Parameter to "SET" the temperature from the massive list "EZ-ZONE ALL Modbus register list in Excel" located on Watlow's website http://www.watlow.com/literature/manuals.cfm?prodmktcat=3&famid=15 ?
mcnearymw
(3,482 Views)
Hi mcnearymw,
I will be glad to help you with any LabVIEW issues you're having, but this issue seems to be related to Watlow's documentation.  It is possible that someone else on the forums is familiar with using Watlow devices in LabVIEW and can give you some advice.  You may want to contact Watlow about this issue.
Good luck with everything!
Jared R.
Precision DC Product Support Engineer
(3,453 Views)
