Watlow F4 Termination
I am using a Watlow F4 to control temperature. My controller has several temperature set points that soak for a duration of time. If I need to stop the profile at any point before it has completed all of the steps I have to manually terminate the profile. Is there a way to terminate a running profile through Labview?
(2,670 Views)
What you can and cannot do is independent of LabVIEW. You have to read the manual to see what, if any, command you can send. You would need an appropriate connection to the controller as well.
(2,656 Views)
