Wavefor Graph to PCX/BMP?
I need to save a Waveform Graph (it is the trace of an oscilloscope) to a
graphic file (.pcx, .bmp...).
The only similar program I've found is one that writes an intensity graph to
a .pcx file, but this is not what I need.
Can anyone help me?
Thank you very much in advance,
Cristina
(3,430 Views)
You can probably use an example from NI's Example Program Database. Try this
link:
http://digital.ni.com/explprog.nsf/websearch?SearchView&Query=vi+panel+image
Or go to the NI EPD (http://www.ni.com/support/epd/) and search for "vi panel
image".
There are LV 5.0 and LV 5.1 examples there that do what you're after.
John Lum
Cristina de Negueruela wrote:
> Hello,
> Can anyone help me?
> Cristina
(3,430 Views)
