Waveform Chart Scale
hi , cbutcher!
Can you explain about what "plot Y scale index" can do?
My target is each Y scale and data that plot can change scale seperately.
Is it possible?
Anyway, Thanks!!
Message 11 of 12
(712 Views)
@Vindecua wrote:
hi , cbutcher!
Is it possible?
Anyway, Thanks!!
Sure - the Y Scale Index chooses which scale the plot should be on.
So if you have 2 scales and multiple plots, you can go from plot to plot using the Active Plot property, and then change the Y Scale Index to switch it between scales 0 and 1, for example.
These scales can change their range separately, along with visibility and a collection of other properties as you've already seen/tried.
GCentral
Message 12 of 12
(706 Views)
