Waveform Chart Usage
I don't understand control and simulation parameters setting. Waveform chart is not not works like a oscilloscope. How can I do?
(3,824 Views)
Hi Mustafa,
Yes, correct observation: a chart is not a scope!
(You know there's a "scope mode" for charts? This is taught in beginner courses for LabVIEW…)
How can I do?
What do you want to do?
How is the attached image related to your VI?
(3,590 Views)
@GerdW Thanks..
I'm dealing with electronics. I am a beginner for labview and I have not received training.
1Hz signal is displayed properly. 100hz is not displayed properly. Oscilloscopes has a time/div switch. Is there no such setting on the waveform chart?
(3,540 Views)
Accepted by topic author mustafayilmaz
Hi Mustafa,
Did you notice those "Training resources" offered in the header of this LabVIEW board?
Switch off X axis autoscaling and set your own x scale values to see the waveform with more details…
(It's the same with a scope: using the wrong x scale settings will also not show the desired waveform.)
A waveform chart is not a full-featured scope. It's just a chart.
It displays just what you want it to display. Nothing more, nothing less…
(When you want to implement certain features in your VI then you need to implement them!)
(3,529 Views)
