Waveform Chart in array
HI
How i can put a waveform chart in a array?
is this posibel ?
(3,297 Views)
It doesn't seem like it is possible.  But why would you want to?
An array of graphs or charts isn't a logical construct.  One problem it would have is that an array requires the properties of all elements to be identical, only the values can vary.  Charts and graphs have so many properties associated with them  (scales, plots, legends, ....) that you really couldn't distinguish one graph from another in the array.
(3,293 Views)
You cannot create an array of waveform charts, nor graphs.
Christian
(3,273 Views)
But you can create an array of clusters containing waveform graphs, right? If you want to create a modular front panel of graphs etc.
Even
_________________________________
Certified LabVIEW Associate Developer
Automated Test Developer
Topro AS
Norway
(3,271 Views)
