Waveform Chart problem in labview 2009
In LV 2009 Waveform chart there is a issue between display format change(relative time/abs time format) with x scale style & vertical grid style.
Once the display format changed to the relative/abs time format then corresponding x scale type & x grid style properties getting affected. Bug fixed?
Try it in this order:
In Waveform chart set the  X scale style type to 0.
Then choose X axis only Major Grid style type.
Then change the display format from floating point default to Relative time format.
Now X scale style type automatically changed to 1 but in properties page it is showing the chosen style 0 only.
Now If you change the Major Grid color from bright default green to ledoff color. Now that grid style also vanished.
(2,732 Views)
Waveform graph also has the same issue.
Kousy
(2,718 Views)
