Waveform Graph trigger
I have a Labview 'read IQ' function reading a digitiser that is sending data to a Labview 'wavefrom graph' in a while loop. I can see the continuous analogue waveform but it scrolls slowly across the 'waveform graph'. On a real oscilloscope I can just set the trigger level to hold the waveform still; how can I get the Labview 'waveform graph' to hold the continuous analogue waveform still as there is no trigger level function that I know off, or should I be using another type of Labview graph/method?
Labview 11
(3,832 Views)
You can use a case structure and place the waveform graph inside.
This case structure can be controlled by a simple boolean control or you can compare if the value is greater than a setpoint,
Guilherme Correa
(3,806 Views)
With that case structure the waveform either freezes (or disappears) when the incoming waveform is below the threshold level. Above the threshold level then there would be a snapshot. What I wanted was a method that would behave more like a traditional scope, where the waveform appears continuous but holds on the peak of the incoming waveform rather than scrole of the screen.
(3,752 Views)
