Waveform Graphs / Indicator refresh rate
Hey everybody,
is there a simple way to reduce the refresh rate of an indicator or - more specifically - Waveform Graphs / XY-Graphs? I'm building an USRP-System and the graphs showing the received signals have an enormous impact on the attainable bandwidth. I'd be happy if the graphs showed only every tenth or so array they are linked to, since the received signal barely changes in that period of time.
Thanks for your help
(3,269 Views)
You may also be trying to graph too.much data. How many data points are there per plot? If that number is large, try decimating the data before graphing it. You aren't seeing all the data anyway.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(3,264 Views)
