Waveform Graphs: Is there a way to save data to a file and then clear the graph after each run?
This is just an added feature that I would like to insert because I end up having to erase the previous graph(for viewing and simplification purposes) after almost every plot cycle. Does LabVIEW 7.0 have a built-in feature that allows the user to automatically clear the graph after each run.
Thank you,
Keith Blackwell
(3,668 Views)
Keith
on the block diagram:
right click the graph terminal --> create property node , right click the property node and change to read. then left click the property node and pick value. then right click the property node and create constant, this will clear your graph when it is executed...
good luck
Dan
(3,668 Views)
It isn't a graph specific feature, but there is a VI setting to clear
indicators before the next execution begins. When this isn't
sufficient, there are always locals.
Greg McKaskle
(3,668 Views)
Dan,
Thanks for your advice, but it did not seem to work. The plots seemed to start immediately after the last ones from the previous command cycle (which I think are the default settings). What I wanted was for the scale to reset (back to the origin) moreso than the graph. I apologize for not being thorough in my questioning.
Keith Blackwell
(3,668 Views)
Thanks Greg,
I went into the function pallette-->signal manipulation-->align and resample
and found something that may be useful, but I'm not sure how to use it. I guess I have to play around with it by trial and error. Was this the VI seetting that you were referring to?
Keith Blackwell
(3,668 Views)
> resample
The option I was talking about is for the entire VI. It resets the
value of all indicators prior to running. The setting is located in the
VI Properties dialog on the execution page I believe. In the end, there
are multiple ways to get this to work, and if you want just a few
indicators to be reset, you want to use locals or control methods, but
th eVI Properties is a convenient way to get all indicators cleared at once.
Greg McKaskle
(3,668 Views)
May I recall you that to clear a graph you have to create a property node,
choose value and connect an 1D array with its first value to zero.
Then using a Select vi enables you to choose from clear or graph value.
Gérard
Gérard Férini
Switzerland
http://home.tiscalinet.ch/gferini/
remove -move to reply personally
"Greg McKaskle" wrote in message
news:xEmJc.43762$mY2.17348@fe1.texas.rr.com...
> > resample
o?
once.
> Greg McKaskle
(3,668 Views)
