Waveform and Complex Numbers
Great; in LV 7.0 Complex Numbers were included as an allowed subtype of Waveform data.
Bad; the vis supporting Complex numbers in Waveforms have a large number of errors. Many Vis does not handle complex numbers and therefore strip off the complex part at the output of the vi. I spent a lot of time to discover and correct the errors in the vis that I used.
Are NI or anybody else working on a patch for these VIs (part of vi.lib)?
(2,965 Views)
You can let R&D directly know of these problems by going to www.ni.com >> contact NI >> feedback (bottom left). These reports go directly to the R&D managers. You can also contact tech support and have them file a report of the bad behavior. Be sure to provide example program and specific information.
(2,965 Views)
