Waveform attributes
Is there a list of waveform attributes that can be reused in labview 8.51?
I am interested in using the pre existing attributes to minimize the code I need to write to display (Graph) my data, such as the plot channel name.
Does anyone use the waveform attributes outside of express daq vis?
Paul Falkenstein
Coleman Technologies Inc.
CLA, CPI, AIA-Vision
Labview 4.0- 2013, RT, Vision, FPGA
(4,217 Views)
For the rare occation when I can use the channel names set-up in MAX, yes I use them. But that is mainly for the channel name.
Since the attributes can be anything you set, there is only a limited set of established attributes which is listed under the detailed help for the "Get Waveform Attributes Function". I never did manage to harness the functionality of the units since "crossing the streams is bad"* is just not allowed.
I hope that helps,
Ben
* Ghost Busters, Using multiple units types in an array.
(4,211 Views)
