Waveform chart real time plotting
Hello everyone,
I am a new LabVIEW user and learning the software by following some books and other online stuffs. My doubt is regarding waveform chart, i made a simple program using random number and plotting it on waveform chart. As plot is being generated over a period of time the values on X-axis keep changing. Is there a way such that i can make a program such that my X-axis is always starting at t = 0 and even if run the program for 2 hours the chart should be showing the values from 0 seconds to 7200 seconds.
I know that a waveform graph can show this. But i want plotting in real time
Thank you
(4,011 Views)
Hi asai,
Then why don't you use a graph?
How is this related to use a chart or a graph? And how do you define "realtime"? (I'm sure you mean something completely different than most of us…)
To answer your question:
- set the x axis to autoscale
- set the chart history to a value allowing the chart to buffer enough samples…
Why this is bad:
- how do you want to display values from 7200s to a chart of ~500 pixels width?
- allowing large history buffers will make your VI slower
(4,000 Views)
Hello sir,
Thank you for the reply.
Okay let me give more clarity about my problem. Suppose i am measuring temperature and plotting it on a waveform chart, after 3-4 hours of running VI continuously if i want to see what is the temperature at 15th minute on a waveform chart how can i manage to do that?
Since i am going to work on real time monitoring of bio-process reactions which take place for 36-48 hours. And i want to know what happened to particular parameter at 3rd hour for example how can i visualize that on waveform chart?
As you have mentioned if i increase buffer VI is becoming slow.
(3,992 Views)
Hi asai,
48h at sample rate of 1S/s gives you 172800 samples/channel: set your chart history at least this size…
But: the data of one channel will need 1.4MB of memory. How many channels do you use?
Separate data display from your DAQ loop using a producer-consumer scheme.
Store your data also in a file (this should be done even before displaying the data in a chart).
As said before: set x axis to autoscaling and increase chart history size…
General comments:
- Usually you don't display that large amount of data on tiny charts or graphs.
- Usually data is decimated before display (to minimze memory footprint and use a reasonable amount of pixels as mentioned above).
- You could keep your data in memory (1.4MB per channel, with 100 channels still less than 150MB) and only display the relevant data in a graph: let the user choose time range and filter your data as needed…
- keep a log file with relevant notes (like "channel AB has changed significantly at HH:MM")…
(3,979 Views)
