Waveform data length not correct
Dear All,
I need to develop an application that logs snippets of signal/waveform.
Meaning, for every y period of time, log signal/waveform during an x period of time.
For this end, I have developed an app that goes through the following steps:
  • Simulate and log a sine waveform with a specific dt, t0 and Number of Samples.
  • Compute and Monitor timing to detect multiples of period y.
  • When period y, start logging waveform. Stop when k*y+x period is achieved.
  • repeat until period Number of Samples*dt is achieved.
The problem is that when I check the TDMS Log file, I can clearly see that lengths of the channels (original signal, snippet signal) are not what I was expecting.
Though the Y components of the signals are correct, the waveforms logged yielded channels with lots of additional values..
Can you please explain why is that? and Should I log the Y component instead?
The VI is attached.
Thanks!
(3,570 Views)
Correction:
Even the Y components do not have the right length. Apparently it's a a programming problem from my side..
(3,536 Views)
Accepted by topic author REaymane
Why do you have an input for both Sample Frequency (Fs) and sample time (dt)?  dt = 1/Fs.  Do not give the user a chance to mess that up.  You can get the dt from the waveform coming from the Sine Wave function.
Your snipetted waveform calculation just seems weird.  You could just use Array Subset to truncate your data instead of the FOR loop.
You can also wire up the waveform to the top of the Build Waveform and then only update the items you need to (it works a lot like Bundle By Name).
(3,525 Views)
