Waveform data
Hello guys, the current waveform chart has all sensors approximately 130 to be plotted. Is it possible I can split this into multiple charts, each has 8-10 plots?
(4,561 Views)
Split up the Y array into multiple arrays and feed them into a graph.
(4,552 Views)
So, for each split array, I'll need the same function ( a build waveform inside a while loop) for each array to plot separately?
(4,536 Views)
Use Array Subset to break up the Array of Waveforms into the groups you want and wire those groups to the different charts.
(4,513 Views)
Thanks for the reply, the data coming into the while loop wire to Y is a 2D array, should I put the array subset between the output waveform and the chart, and specify the index as 0 and length as 8 to plot first 8 plots in one waveform chart? As shown in the fig TO joint #1 strain gauge data. Thanks.
(4,509 Views)
Does that give you the result you want?  From my understanding, that is the way to get what you want.
(4,504 Views)
