10-06-2005 03:19 PM
10-07-2005 09:20 AM
@Barneyho wrote:
Derek, did you have to keep your volts scale on the left side then? I've got this issue and still can't seem to make it work. I need my 'volts' to stay on the left side of the screen (just because thats where it was while my program was running LabVIEW 6.1).
The x-scale alignment will remain OK. Have you tried this?
10-07-2005 12:02 PM
10-07-2005 12:52 PM
You seem to have a somewhat different problem.
First, you need to disable "Auto adjust scales" for all charts, this causes the plot size to change depending on the space needed for the axis. You should also change the formatting of the y-scales for e.g. a fixed number of decimal digits so their lenght does not jump as much depending on scaling. Leave enough room for the largest expected numbers. Since you only have one x-axis you must ensure that all plots remain aligned. Autoadjust scales is this not allowed.
You should also do a "Reset scale layout", then resize the graph to the desired size using the outer boundaries, not the graph area. This avoids all the overlap. (remove the transparency on the background temporarily for better control).
See how far you get. 🙂
10-11-2005 02:54 PM
Nice Post Christian!
I had written this bug off.
This thread has been added to the "Interesting" list here.
http://forums.ni.com/ni/board/message?board.id=BreakPoint&message.id=1117
Ben
08-25-2006 02:59 AM
08-28-2006 01:29 PM
