Waveform graph data points limit.
Is there a limit on how many data points a waveform graph can display?
(4,922 Views)
Hi zomboy,
the technical limit is the available memory…
Practical limit is the width (number of pixels) of your graph! It doesn't make sense to display a milion data points in a graph less than 1000px wide.
(4,905 Views)
It depends what you want to see. If you want to plot the average of the last 1000 datapoints from a sensor, then 1million data points would fit nicely across 1000 pixels. Mike Porter has a very nice post on plotting large data sets here:
http://www.notatamelion.com/2015/07/31/plotting-large-datasets-without-waiting-forever/
(4,877 Views)
There are several soft limits. For example if you try to graph 2k plots, each with 4 points, your UI will basically saturate one CPU core while the same number of points graphed as 4 plots with 2k points each will be no problem.
(4,860 Views)
