Waveform graph plot legend in labview 8.5 won't respond to arrow keys?
I heard labview 8.5 fixes most of the problems that plague 8.2, so I recently installed it to try it out and see if it is worth the effort of another upgrade.  Messing around today, I found an issue that wasn't related to the installer itself.
The plot legend on a waveform graph doesn't appear to respond to arrow keys for precise placement.  It doesn't matter whether auto-size plot legend is turned on or off.  When I want to place a plot legend very precisely, just like with any other labview control I like to use the arrow keys to get things perfectly aligned.  I want to make the plot legend perfectly in the corner of the graph but its very hard to get it placed right with just the mouse.  In labview 8.5 it seems like plot legends no longer respond to arrow keys.
Can anyone confirm this or know of a way to precisely place the plot legend in labview 8.5?
-Devin
I got 99 problems but 8.6 ain't one.
Message 1 of 18
(3,786 Views)
This behaviour seems to be specific to your own setup. No problem on my PC.
Sorry !
Chilly Charly    (aka CC)
Message 2 of 18
(3,774 Views)
What about on the classic waveform graph?  That is where I saw the problem.
-Devin
Message 3 of 18
(3,759 Views)
No problem either with the classic graphs. Sorry again !
Message Edité par chilly charly le 11-08-2007 01:17 PM
Message 4 of 18
(3,756 Views)
billings,
Have you verified this behavior on another computer? If it's only on your current computer, you might try a Repair of the LabVIEW install. You can do this in Add/Remove Programs.
Cheers,
Emilie K | Applications Engineer | National Instruments
Message 5 of 18
(3,738 Views)
Snap to grid?
Ben
Message 6 of 18
(3,730 Views)
This is a vi has a control that started in 6.1 and has been maintained through several labview versions.  Its just a control on a blank vi, but I can't move the palette with the arrow keys.  Can anyone else?
-Devin
Message 7 of 18
(3,713 Views)
No problem in LV 8.5. The problem is on your side ! May be something corrupted in your LV install
Message 8 of 18
(3,700 Views)
Ben,
I checked the snap to grid hypothesis. Even when activated the arrow keys still allow an accurate positionning of the objects at pixel level.
That's so nice that I changed my setup. I now have a reasonnably large spaced grid (50 pixels) with an invisible grid (contrast adjusted to zero). That should make object positionning and dimensionning much faster than before. 🙂
Message 9 of 18
(3,695 Views)
Well I'm not suprised.  The repair option doesn't seem to do anything useful.  Last thing I did was a brand new clean install of the DVD and it doesn't help.  I guess I should manually delete everything and try again or something.
Message Edited by billings11 on 11-09-2007 01:48 PM
-Devin
Message 10 of 18
(3,694 Views)
