Waveform graph start from zero
Hi I have program where a load array is already generated using a subVI. the starting amplitude of the load is a non- zero value as show in figure. Without making any changes in the subVI or load array I want the dotted line to start from zero amplitude at the current timestamp (No modification should be made for the time-axis). I tried Build Array to add a zero in the beginning of the graph but it messes with the last value (i.e. it causes the vertical dotted line at the end of the graph disappear). Kindly help.
(3,055 Views)
Hi shreya,
don't create double posts for the very same topic!
STICK WITH YOUR ORIGINAL THREAD!
(3,035 Views)
Graph will display whatever values present in Array. If you don’t have “Zero” amplitude in the Array then it won’t start from zero.
Munna
(3,025 Views)
