Waveform graphic / chart time display (x-axis) is wrong?
Why the time is incorrect in waveform graphic / chart? How to solve it?
When I run the program, I find that waveform graphic/chart show 0 to 20 (time/x-axis) but actual is running 30 second.
(3,863 Views)
You need to specify the timing information with "build waveform".
Yik
Kudos and Accepted as Solution are welcome!
(3,842 Views)
Where to set "build waveform"?
(3,820 Views)
The Build Waveform is on the Waveform palette. You can use it to set the dt. It's a fancy cluster. The dt is your loop rate in seconds. I would assume you have some wait or delay function that you are using to set the loop rate.
You can also use a property node - XScale.Range. Offset and Xscale.Range.Multiplier. Look at the example called Real Time Chart.
(3,817 Views)
Well, I guess the first question I have is which do you have, a 'chart' or a 'graph'.
That will make a difference when you want to set the xaxis.
Cory K
(3,805 Views)
