Waveform not smooth and frequency of waveform can't change
I have taken out the loop of the example vi. I can run the program and change the amplitude but i have some problems:
1. When i change the frequency, the frequency of the waveform generated doesn't change.
2. The waveform generated is not smooth. (try to run the program few times)
I have attached the program. Please help me to solve the problem.
Best wishes. Chan
(2,458 Views)
Hello
I can't see your Vi since it's saved in LabVIEW 7.1 version. Look at the LabVIEW examples, many times there you'll find the answers you're looking for. Here is a Vi that I took from there.
Message Edited by Robst on 02-17-2006 10:40 AM
Robst - CLD
Using LabVIEW since version 7.0
(2,452 Views)
Hi Jason-
Let's keep the discussion here for convenience.  Thanks!
Tom W
(2,432 Views)
