Waveform question ! 2 or more Y
I want to build a real waveform data with more than 1 Y
BUT I have serious touble with this 😞
But if I do so also only the last y shows up why ? (Graph or Save as spreadsheet)
What do I have to do if I want to have more than 1 y in my waveform ?
If I build one by hand for the Waveform graph (array -> Bundle)
it is a cluster ...
is it possible to convert this cluster to a real waveform ?
(3,027 Views)
Try this:
Build 2 clusters and concatenate them using the Array-> Build Array function (and adding an input).
-Matt Bradley
************ kudos always appreciated, but only when deserved **************************
(3,026 Views)
When using the 'Build Waveform' primitive, you can only specify one Y array input. If you add more than one then the last Y array input gets used.
Chris_Mitchell
Product Development Engineer
Certified LabVIEW Architect
(3,026 Views)
