Waveguide alignment
please give some idea,how to make it faster and get the highest efficiency?how to write a labview programmed in this automation?please help!
(3,356 Views)
I believe we need a little more information to give you a useful answer.
Eric
Eric P. Nichols
P.O. Box 56235
North Pole, AK 99705
(3,356 Views)
Are you physically moving waveguides to align to a connector? Maybe you are tuning a set screw. Do you have a mechanical device to do the alignment (stepper motor or something)? Do you have a meter to measure the power out? You could have a loop take the reading, step the motor in one direction. If higher output, continue stepping until power goes down. If lower, step in opposite direction. If this is not what you want, be more specific.
- tbob
Inventor of the WORM Global
(3,356 Views)
"how to make it faster and get the highest efficiency?"
please define what "it" is.
The spped is dependent on the mechanical, control and sensing sub-systems.
Please share details on each of these sub-systems so we can help.
Where do you suspect the current system can stand the most improvement?
Ben
(3,356 Views)
