Wavelet
hi all!!
i am doing a project on wavelet transform
for the first step i need to plot the datas with wavelet function
the data is in two columns with time in one column and amplitude in another column
kindly help me!!!
i am new to this wavelet function.
(4,316 Views)
Do you have the Advanced Signal Processing Toolkit? What are you trying to accomplish with wavelet transforms? There are numerous examples available on this site, so you may want to look those over.
(4,304 Views)
yes sir
i have installed labview 2013 with advanced signal processing tool kit
(4,266 Views)
You may want to look over these examples to get you started. These are just a few random ones that I found on this site, as I don't know what you are trying to do with wavelets:
https://forums.ni.com/t5/Signal-Processing-and-Analysis/Signal-Processing-Application-Detecting-Clic...
http://www.ni.com/example/30699/en/
http://www.ni.com/example/30684/en/
http://www.ni.com/example/30649/en/
(4,242 Views)
 many thanks for the reply sir.
(4,206 Views)
first of all i  need to get the wavelet graph
for the given data which contains time in one row and amplitude in another row sir.
i have tried using READ FROM MEASUREMENT FILE box and connect it to the continuous wavelet transform but  i can/t get the resultant waveform sir.
so using which option available in wavelet we can plot the graph?
kindly help me!!
(4,200 Views)
hello sir,
also i have looked the links
how to give a user definrd file to wavelet
also for reading the measurement file which wavelet box i need to select?
Kindly clear my doubt.
(4,171 Views)
