Wavetek 9100 - Error 1073807339
Hi my name is Said and I work in the National Institute of Industrial Technology of Argentina, in a calibration lab. We have a Wavetek 9100 Calibrator, Agilent 34401A Digital Multimeter and a NI GPIB IEEE-488-2 board. I have a problem with the Calibrator driver, in the transition from 90 V to 110 V in the DC and AC Voltage the instrument starts to ring an alarm and the program shows me the follow message: "Error -1073807339 occurred at VISA Read in wt9100 Error Query.vi->wt9100 Configure Output State.vi->wavetek multipoint VCC con array desde txt modificado 1.vi" and "Possible reason(s):
VISA:  (Hex 0xBFFF0015) Timeout expired before operation completed."
Can you help me?
Thanks.
(4,348 Views)
Good afternoon, I sent these links for help verify that the errors occurring. Any questions please contact us. Why do I Receive Timeout Error -1073807339 on VISA Read or Write? http://digital.ni.com/public.nsf/allkb/874B379E24C0A0D686256FCF007A6EA0?OpenDocument Error -1073807339 When Using VISA Read or VISA Write in a Serial VI http://digital.ni.com/public.nsf/allkb/E6DFA2B8D7E99F9886256C14005E82F7?OpenDocument Sincerely, Mauro Vera.
Mauro Vera
(4,303 Views)
Hi Sirs,
Please anyone can help me regarding error message on WAVETEK 9100; The unit is in stock for almost 2 years and it was owned by my company before, and it was closed now, and then when i started to operate the unit, the unit display reads "Selected test has failed number of failures 8" then all keyboard or button are all in active or not functioning and nothing happens on the display, it always hanged.  What will i do, the manual says no detailed. Please help me on my problem.
Thanks and Regard to everyone.
Thanks and regards,
JOHN MARK
(4,164 Views)
What does this have to do with LabVIEW? You have hijacked an unrelated thread.
Questions about your hardware should be addressed to the vendor.
(4,159 Views)
