Hello TantoK,
As far as I know, the only way to programatically figure out which version of a particular NI software is installed is to check the registry. Registry entries can be found under the following:
\HKEY_LOCAL_MACHINE\SOFTWARE\National Instruments\
As for licenses, I am not sure. I will check and let you know if I find something.
Mas Chano
National Instruments Japan
