Ways to smoothen signals
Hi All,
My program DAQ input from my labview reads a wide range of values. From negative milivolt to 0.435volt for example. Is there any way to smoothen the signal? Currently, I'm using the 'collector & statistics'. Every time I change my collector-max number of samples by increasing it, the values is almost like 20-21 Degree Celsius.
Is there any other way to smoothen signals? Thank You.
Isa
(3,038 Views)
When you say "smoothen" do you mean to reduce noise on the signal? If so, there are a number of techniques. One method that is easy to implement is a 3-point running median.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(3,023 Views)
Hi mike,
but what is 3-point running median?
Thanks & Regards,
Isa
(3,017 Views)
http://en.wikipedia.org/wiki/Median_filter. Also have in mind Isabella, that Google is your true friend. Always there for you 😉
Besides which, my opinion is that Express VIs Carthage must be destroyed deleted
(Sorry no Labview "brag list" so far)
(2,987 Views)
Hi
  Can yuo send me the screen shoot of your graph or chart.Do u want to filter the noise or smoothen?You may try to use filter if you wan to remove noise.
Let me know what eaxctly you want?
Regards.
S.Ahmad
AE
(2,963 Views)
