Web Server Message Boxes
Does anyone know of a way to control the Web Server message boxes that popup for a given action i.e Control Granted or Server has Control etc... I would like to be able to disable the messages in certain cases and so far have been unable to find a way of doing so.
Your help is much appreciated.
Dave.
(3,168 Views)
Hi Dave,
Could you post your code? It would help me see if it is something that can be done programmatically or whether it is a case of adjusting settings/configurations.
Emma R
NIUK & Ireland
(3,153 Views)
Emma,
Attached is some development code i've been playing with. When you run the front panel from the Internet Explorer, you will see the message boxes appear when the panel has loaded. I would like to prevent these messages from appearing but can't see a way of doing it.
Thanks for your help,
Dave.
(3,140 Views)
Hi Dave,
When I attempt to open your code I do not have "Web Server Password Login2.vi" VI or the type definition named "Password Enum.ctl" so I cannot run your code.
Can you post both of these items?
Emma R NIUK & Ireland
(3,113 Views)
