Web Service Error during "Publish" Application Web Server
Hi All,
I have an error during Web Service "Publish" as attached screen shot.
My goal to connect with Labview NXG Web Module once "Publish" succeed. Please someone help me & advice for the error.
FYI, I am using Labview 2014 32bit running on Win10 64bit
(3,441 Views)
This might be overly simple but maybe try closing out of LabVIEW and rebooting. The error suggests that the file mentioned is already loaded into memory/and can't be copied to that location: "A LabVIEW file from that path already exists in memory, or exists within a project library already in memory."
Error copying files.
Source: C:\NI Week Demo Source Code\2019_CG_WebServices\WSsupport\Check if Session Exists.vi
Destination: C:\Users\ptpmsufi\AppData\Local\Temp\lvtemporary_144157.tmp\internal.llb\Check if Session Exists.vi
Invoke Node in AB_Source_VI.lvclass:Set_VI_Path.vi->AB_Source_VI.lvclass:Copy_SourceItem.vi->AB_Build.lvclass:Copy_Files.vi->AB_Build.lvclass:Build.vi->AB_RESTfulWebService.lvclass:Build.vi->AB_API Do Two Step Build.vi:4020001->AB_API Build.vi:4700001->NI_AB_API_Build.lvclass:Build.vi->NI_AB_API_RESTful.lvclass:Build.vi->NI Web Service Build.lvlib:Build Web Service.vi:3720001->NI Web Service Build.lvlib:Create_Rest.vi->NI Web Service Build.lvlib:Create_Rest.vi.ProxyCaller
<APPEND>
Method Name: <b>Set Path</b>
<Call Chain>Error 1357 occurred at AB_Source_VI.lvclass:Copy_SourceItem.vi -> AB_Build.lvclass:Copy_Files.vi -> AB_Build.lvclass:Build.vi -> AB_RESTfulWebService.lvclass:Build.vi -> AB_API Do Two Step Build.vi:4020001 -> AB_API Build.vi:4700001 -> NI_AB_API_Build.lvclass:Build.vi -> NI_AB_API_RESTful.lvclass:Build.vi -> NI Web Service Build.lvlib:Build Web Service.vi:3720001 -> NI Web Service Build.lvlib:Create_Rest.vi -> NI Web Service Build.lvlib:Create_Rest.vi.ProxyCaller
Possible reason(s):
LabVIEW:  A LabVIEW file from that path already exists in memory, or exists within a project library already in memory.
(3,405 Views)
Hi fblerg,
Thanks for the reply.
Yes, I also thought same with you, done reboot & below steps but the error still same.
Now I try checking each vi.
- close LabVIEW
- delete all the folders starting with "lvtemporary" located       at C:\Users\ptpmsufi\AppData\Local\Temp
- open LabVIEW
- clear the compiled cache (Tools»Advanced»Clear Compiled Object Cache)
- try to build again
(3,398 Views)
Accepted by topic author Yan_Sufian
Hi fblerg,
I have found the solutions for below error.
It happen on my created sub.vi "Check if Session Exists.vi" itself where I am using "Check if session Exists.vi" in vi library on the sub.vi (same name). I have rename my sub.vi & error solved.
(3,392 Views)
