Web Service with URL redirect
This seems a bit silly--it should be trivial--but I'd like to be able to direct users to:
http://<DNS name>
instead of:
http://<DNS name>:<port number>/<Web Service Name>/<static folder name>/<HTML wrapper name>
Any hints on how to do this with the LabVIEW web service?
(4,615 Views)
I'm not pretty sure, but by default, if you type :
http://<DNS name>, it will try to reach the 80 port (http) the html page called index.html
So several solutions :
1) redirect the 80 port on your routeur to the NI web service port (8000)
or
2) Change the web server HTTP port (default 8000 to 80)
For the rest, I think that the html page should be called "index.html" to be launched automatically.
Hope this will help you to solve your problem !
V-F
(4,600 Views)
Thanks for the reply... I had forgotten that the HTTP port was port 80, so that was helpful. My main difficulty was in understanding where index.html should be placed, but I believe it is in:
National Instruments\WebServices\aws\
[for what it's worth!]
(4,584 Views)
I think the index.html should be placed in : National Instruments\LabVIEW 2011\www
Best regards
V-F
(4,577 Views)
Turns out neither of us was right. Through trial and error, it works only in:
National Instruments\Shared\NI WebServer\www
[although the web server does not serve index.html automatically when http://<DNS name> is called. I still have to use http://<DNS name>/index.html. By default, WIF.html is the directory index.]
(4,527 Views)
