Web Services on cRIO-9068
I am setting up web services on a cRIO-9068 following the guidance here:
https://forums.ni.com/t5/LabVIEW-Web-Development/Getting-Started-Series-Hosting-Web-Service-on-a-Rea...
However, in Web Service properties, the HTTP Method VI Settings section with the Web Services (URL Mapping / Output Type / Security / Advanced tabs is disabled/greyed out. Does the web service need to be enabled elsewhere for this to appear? My files show up on the site map with each method and URL mapping listed, just not within.
(3,160 Views)
Wording could have been a little confusing in last post. Here is a picture for reference. webservices.png
(3,117 Views)
Visible files in Site Map section.
(3,114 Views)
Although I do not have an immediate answer, you may want to consider following our official tutorial on this as opposed to the form post:
https://www.ni.com/docs/en-US/bundle/labview/page/tutorial-creating-and-publishing-a-labview-web-ser...
CH
Applications Engineering
http://www.ni.com/en-us/support.html
(3,075 Views)
I had incorrectly placed the web method files generated in Web Resources under the Public Content folder. Once these were moved, the HTTP Method VI Settings table worked fine.
(3,061 Views)
