Web Services session variable
1 - i've the following problem i've a VI that write in the output channel of a DAQ card a certain value of voltage, i can write to the output channel any value between 0 to10, because im using a labview 8.6 i decide to create a web service wich  works, my only problem is that my web service only accept the first value of voltage that i use, how can i've a persistent variable in web services, i try to found samething the web services pallete but didnt work, can sameone help-me?
 2 - my second question is the next when u've a labview web service where do u find the generated xml file? im asking that because i need a rest client for my labview web service in PHP, i still making my way to this new feature of labview.
(3,806 Views)
Hello mngolo
First of all, I have problem with your tzid.zip. I could't unzip it. I don't know if it's me or not but could you attach it again please? It should be helpfull for me to have a look at your code.
It's an easy example with Web Service. I assume you created well your Web Service but I want to be sure you didn't forget a step.
Best Regards.
Romain D.
National Instruments France
(3,776 Views)
hi Ramain D. tanks for your help here is my project again, i already try the examples and work fine, tanks for your help
(3,771 Views)
Hi mngolo.
I try to unzip your attached file but I can't. Two of my colleagues try too but they have the same issue. We've got about 8 error messages. It should be hard for us to help you or to reproduce your issue without your code Smiley Sad .
I advice you to contact the NI support by phone, I think it's the best way to solve your problem.
I am very sorry that I can't help you more on your problem. Could you share/post the solution when your problem is solved with the support please? I am interesting to know more about your issue Smiley Wink.
Thanks in advance.
Best Regards.
Romain D.
(3,750 Views)
hi i send the project again unzip, maybe its a problem of my software can u please check out, tanks, the vi that i need your help is called tzidwrite.vi
(3,729 Views)
