Web Services wsdl file
Hi Chuan19,
thanks for your response.
I had already checked out the links you posted, but was hoping that there might be a better (automated) way.
I could write a GET VI manually which returns all other VIs, including their parameters, but that's a bit tedious and I also have to adapt it each time I add another VI or modify one of the existing ones.
I suppose there are no simple ways to do this?
Also: is there a specific reason why LabVIEW allows the import of .wsdl files, but does not support the creation of them? I understand they use a RESTful architecture for their web services, but that doesn't synergize with .wsdl, does it?
Message 11 of 12
(441 Views)
Basically, the feature to create web services in .wsdl is not available in LabVIEW, and the RESTful architecture does not comply with the same standard.
Message 12 of 12
(430 Views)
