Web application with DAQ
Hi Skeggy,
you can use a while loop too, but, since you want the VI to show every acquisition point, inside the while loop the data must be sent to a shared variable and there must be another VI that reads the data from the shared variable and sends it to the web.
As your application works fine, it's good as it is, they're just two ways to solve the same problem.
Thank you for your feedbacks,
byebye!
FBM
Message 11 of 11
(391 Views)
