Web publishing a VI
I want to publish my VI on the web browser to monitor it remotely. I have enabled the remote sever on Tools->Options->Web Server. when I click Configure Web Application Server , I could not view the configuration screen on my browser.
I tried the steps that has to be followed in web publishing tool. But my VI doesn't appear . It shows No Plugins available to display the image. what i must do to display the front panel of my VI?
Thanks in advance.
(2,918 Views)
I suspect that you use browser that is not internet explorer to open the panel. Is this correct?
If you open it using internet explorer, there shouldn't be any problem.
If you would like to use any others web browser to open it, you might need to do a troubleshooting step in this link below
http://digital.ni.com/public.nsf/allkb/151BE12C055F57CE86257043006CB4B3
Another factor to this issue is that you don't have LabVIEW run-time engine or LabVIEW installed in the computer that you are trying to open it.
Hope this help
TuiTui
(2,529 Views)
