WebVI JSON Array Issue
Having another Simple JSON issue:
Receiving
but apparently, there is an issue with my decoding
I get an Error -375006
I've also tried connecting a String Array directly into the input to the Unflatten JSON and wiring directly to an Array indicator, but I get the same result.
Please help
KM
(2,228 Views)
Accepted by topic author DeOdderKeith
Hi KM,
The structure of the LabVIEW type should match the JSON value. In this case the JSON Object has a field named "subarray" that is an array of strings. The LabVIEW type is a cluster with a field named "String Constant" with a scalar string value.
In order to match the JSON Value the LabVIEW type should be a cluster with a field named subarray that is a 1d string array.
Milan
Milan
(2,204 Views)
I was missing the name. In this case, "subarray"
KM
(2,198 Views)
