Webcam and LabVIEW
Anyone have experience with the webcam driver for LabVIEW downloaded from
www.mindofpete.org ? I get a grey screen with lines when I run it. I work
with a Logitech USB webcam with XP and LV 7.0
W.
(3,251 Views)
Hello W,
If you go to the vision forums and search for "USB Webcam" there are a number of posts with links and information about drivers and image acquisition in LabVIEW. Below is a link to the vision forums:
http://exchange.ni.com/servlet/ProcessRequest?RHIVEID=101&RPAGEID=8&RFORMNUMBER=3&RHIDETAG=TRUE&UCATEGORY_0=_15&UCATEGORY_S=0
I hope this helps,
Sean C.
(3,251 Views)
hello W,
Were you able to figure out the solution to your problem? coz i seem to same problem..How did you mange to solve it?I also have the same config as you do.
msa
(3,251 Views)
