Webserver cannot be viewed on developer's laptop
Good day. I currently facing a problem to view webserver using my laptop. I had created a data monitoring application with webserver. I build installer and install it at a new computer (computer B) and its working perfectly. I am able to view the webserver in localhost as well as using domain ip in the app installed computer (computer B). The problem is, i am not able to view the webserver using my own laptop which i am used to develop the application. It shows blank page with borders and header title. To ensure my application is working ok, i had tried using another computer with same spec, same OS , same IE version of my laptop (computer C) to access the webserver of computer B. It is working perfectly. There are some steps that i had done for my laptop to troubleshoot it.
1. Install Labview Run Time > I use the same run time installer that i installed at computer C, but it returns that i already installed higher version in my laptop.
2. Disable firewalll and temporary disable antivirus > not the solution
3. Reinstall Labview >not the solution
Any professionals are able to teach me how to troubleshoot/solve this problem? I need to solve this problem as i cannot always using another computer C to test my webserver. FYI, my laptop OS is window 8.1 and IE version is 11.
(2,900 Views)
Did you verify the computers were on the same subnet?
(2,878 Views)
Are you mention IP subnet mask? Yes, they are on the same subnet.
(2,870 Views)
