Webservice: Can't Create Project Library
I'm using the Wizard for importing a webservice. Everything works fine until I try to generate the VI-library. I always get the following error:
.NET Web Service Proxy Tool Report for Web Service: iptocountry
Mittwoch, 24. Juni 2009 18:14:23
Web Service URL: http://www.ecubicle.net/iptocountry.asmx?wsdl
The following errors/warnings occurred when generating the local proxy dll and VI wrappers for this web service.
Can't Create Project Library.
Project Library Generation Failed.
Possible Reasons:
1. The imported project library has a conflicting name with a project library already in memory.
2. The imported VIs have conflicting names with VIs already in memory.
Close the project library and VIs and reimport the Web Service.
iptocountry.lvproj
Possible Reasons:
iptocountry.lvproj
Cannot generate C# assembly.
Error message from C# compiler:
Die Quelldatei C:\Windows\TEMP\q246tgvj.0.cs konnte nicht gefunden werden.
Es wurde keine Eingabe vorgenommen.
I tried the following:
- closing all open VIs and LabVIEW projects
- closing all other programs
- restart the PC
- different Webservices
Nothing helped. It also must be possible to program the wrapper VIs manually. But I didn't find any useful example code anywhere, and the documentation about webservices with LabVIEW is very poor.
Thaks for every help!
David
Message 1 of 1
(3,210 Views)
