Webservice datasize speed problem
Dear all
I just started using Lv Webservice in LV 2009 to transfer data from a file to a Adobe Flex client.
As a reference I used the  "Function Generator's" example file from NI.
Then I translated this project to my needs.
Now I have seen the problem. As long as the transfered datasize is up to about 131kb it needs about 2seconds to show the data.
When you increase the datasize of the transfered data to 132kb it needs about 65seconds. It does not matter if I transfer plain text or XML text.
Also package wise transfer as shown in this thread
http://forums.ni.com/ni/board/message?board.id=170&message.id=349276&query.id=226433#M349276
does not overcome this problem.
Is there somebody out who has also seen this problem or / and even have a solution.
Thank you in advance for your help.
Best regards
Gernot
Gernot Hanel
IONICON Analytik Gesellschaft m.b.H.
(3,360 Views)
Hi Gernot,
I am sorry this took so long. One of my colleagues already contacted you about the issue. I would just like to share the workaround here:
Modify the niwebserver.conf file to have the line "HttpChunking off"
This line needs to go before the line that reads "Listen 80."
The issue is known and documented. Its ID is 203547. You can always find the information which issues were fixed in the readme documents of new releases.
Regards
Peter
Message Edited by PaSB on 02-12-2010 01:32 PM
Peter A.
Field Sales Engineer, NI Germany
(3,300 Views)
Andreas Stark
LabVIEW Lead @ Rocket Factory Augsburg
(3,294 Views)
