Webview2 control with SSO
Hey all,
Been struggling for a while to get SSO to work with LabVIEW in the Webview2 control.
I necromanced an older webview2 post but figure this solo post might get more visibility.
The attached VI is non-functional.  The comment/code snippet in the VI is from a stackoverflow post that I'm trying failing to follow.
Win11 Enterprise Version (10.0.22631 Build 22631)
LabVIEW 2015sp1 (15.0.1f13(32-bit))
Webview2 evergreen
(1,830 Views)
Accepted by topic author beavercreek
Turns out that the above VI works perfectly fine as long as you set the VI Properties -> Execution Category -> Preferred Execution =  "user interface".   Much Thanks to coworker Leban!!
(1,776 Views)
